We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
ok guys i think its just about ready for ricky, i took out on the main road and it did pretty damn well, definitely needs more adjustment when going from driving to parking, it seems to bog down a bit, the afrs seemed pretty good whenever i could look at them, its like 105 degrees today so shes getting a bit hot i wish i couldve gone out for a bit longer
105 degrees, sheesh, I think that's too hot to fly at some of the pilot schools down there.
Anyway, in this last log it still seems kind of erratic. And it quit running at 470 secs but it restarted right away. There's a consistently large negative fuel trim at 1000 rpm idle, but in the other areas it's just kind of erratic. Usually it seems pretty good when throttle is 25% to 35%. Justin's cams are stock 1g (I think) so that would idle quite different from yours.
This screen shot is what was suggested by SD VE adjust(combinedFT). It does suggest a couple of large changes in the 1000 rpm column, and smaller changes elsewhere. You could make these changes but I don't know if you will even notice a difference in how it drives.
I don't see the TPSDelta doing you much good. I've noticed that before, it just doesn't seem to do much.
I wonder about your injectors - did you buy them new? If you got them used, they might need to be cleaned and flow tested. Rust in the tanks of these old cars gets loose, goes right through the fuel filter, and ends up in the injectors.
Never-the-less, maybe it is time to take it to Ricky.
New, good!its a brand new lc-2, it has a calibration section in the manual but my buddy said he never calibrated his and it seems to work fine out of the box
Wow, could you show us a shot of that?it has an internal wastegate but i have that stuck fully closed and am running an external summit unit,
Oh, I imagine the Profec is Ok, although I've never used one. If you are used to the Profec and it works ok then I don't think you would need to change that.for a controller i have the newer profec unit that worked great on my gst, im interested however if using the ECMLINK built in controller would be beneficial
you should juice up your Specs & Photos page! That page is where everybody looks first when trying to help somebody, and your page is pretty empty. This picture is the first thing I'd put there. Plus listing some of the more basic non-stock things like the cams and the specific turbo. Lots of other non-stock stuff I see in there too.
one thing after another
