turbosax2
Moderator
- 4,485
- 683
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
Lately my brother (snowborder714) and I have been piecing together a complete fuel system for his 95 GST (including lines, pumps, afpr, injectors etc.) to be installed in the somewhat near future. I am posting this instead of him because these are mostly my ideas. We're considering going with a Walbro 255 intank pump, which he already has and it is rewired, and a Walbro 255 inline pump. We have read on numerous posts that that Aermotive afpr's do not hold the fuel pressure and will drop to zero in roughly a few hours. People complain that if they let their car sit for a few hours then try to start it, it takes a few more cranks than usual to get it started. To alleviate that problem, some people have suggested installing a switch for the fuel pump. Now, on to my questions for all of you.
We want one switch that will turn on both of the fuel pumps - the catch is:
The switch should not be able to turn the pumps on if the key is in the off position or not in ignition switch.
The switch should not be able to turn the pumps off when the car is running.
The switch should only be able to turn the pumps on or off when the key is in the accessory position.
With that being said, the normal procedure for starting the car would be as follows:
Put key to accessory position, turn switch on to activate pumps and build fuel pressure, start car, turn switch off but pumps continue to run.
We need to know how to wire the switch so that it meets those requirements. Also, we need to know how to wire up the external pump.
I made a crappy drawing on Paint of the only way I could think to do it, but I don't think this way would work. (Ignore the wrong orientation of terminals on relay.) Neither my brother nor I are wiring experts but we understand some of the basics and have done simple wiring on gauges and lights.
Please, do NOT turn this thread into a discussion on need of external pump or need of the switch. I am just interested in how to wire them correctly in case we do decide to go with an external pump and/or switch for the pumps.
Thanks everybody for your help in advance!
