2G fuel pump question
stiggity99
231
4
Mar 31, 2011
York Haven, Pennsylvania
i replaced my fuel pump assembly, fuel pump, and ran -6an from pump to rail. i also pulled the drivers side float and syphon pump, awaiting it's replacement to arrive soon. is it possible to start the car with no drivers-side assembly present? all i want to do is turn the pump on via dsmlink, and flush out anything in the supply line, b4 i connect the filter. Thanks
Should be able to cycle to key to have the pump turn on withbout actually firing the car if you unhook the lines from the rail you could do a flush threw it
Correction, cycling the key will only work if your pump is hard wired / rewired
You are incorrect on both counts. Pump only turns on with motor spinning. If you rewired and used a key on 12v source to trip the relay then yes you are correct. Most people use the stock fuel pump wire to trigger the relay and that does not have 12v with just key on.
