A1000 fuel pump
wvdsm92
74
8
Feb 20, 2013
Elkview, West Virginia
I have a A1000 fuel pump but I don't think it's getting enough power the a1000s are suppose to be loud correct? But mine you can't hear it at all is it because of low voltage? Car runs fine but seems like I run out of fuel quicker than I should I had pte 1000cc injectors HY35 turbo at 26 on e85 and the injector duty cycle was at 89%
Most likely you ARE out of injector. 89% is what you shOuld safely be at. Remember ethanol requires more fuel than regular pump So your 1000's are like 8xx cc's or so.
what gauge wiring do you Run? Fuel filters good and clean?
fuel filters are brand new but haven't checked since I've had them on the car and i think my problem might be the stock wiring i haven't done any new wiring for a fuel pump
