Resolved Fuel pump doesnt turn on.
Joshua1989
May 30, 2013
Regranie, Wisconsin
I drove my car into the garage yesterday just fine and i tried starting it today and the fuel pump doesn't turn on. So i rewired my fuel pump and checked to see if it worked and it did. So i put everything back together and i checked it again and the pump doesn't turn on. what is going on? i replaced the ecu and MPI relay. Idk what else to do. It seems to turn on when it wants to not when i do
Do you have ecm link? You can try turning on the pump manually. If not, jump the relay and see if the pump works. That will tell you if the problem is pump or relay related.
ya i traced the wires and i didnt find anything wrong. Its working fine now so I dont know whats up with it
Solution
