Wow stupid car doesnt turn on now
juan334
Feb 9, 2010
tampa, Florida
so after my recent problems now my car keeps turning over and doesnt want to turn on so wtf is this cars problem?
before it had a bouncing idle and drove great but idle just sucks and now it doesnt want to turn on
and there is no clicks so i dont its the battery because the car turns over but i will check the battery either way
First, use some grammar please. That's just downright painful to try to decipher.
Second, more info or a better description of the problem would be really helpful. The starter turns the engine over, but does it fire at all? Did you have any CELs prior to the no-start condition? Do you have a data logger or a way to read codes? When you turn the key do you hear the fuel pump kick on? Any weird behavior or anything unusual at all from the car before the no-start condition? Just some basic info that may help someone to be able to better help you.
DO YOU HAVE GAS...
Check for spark and fuel, Test you Crank Sensor, Test your Coil, Also you can rent a CEL Tester at your local Auto-zone, Nappa, Murry's, Advanced.
Have you changed anything on the car lately or messed with anything TPS, BISS.
Check your plugs Id say first, see if there black when you pull them out or oil is on them or if there white even. Make sure your setting spark on off of them. Start simple and your your way up the ladder of DSM.
