Dusty Landrum
Supporting VIP
- 1,004
- 1,669
- Jul 15, 2019
Denver,
Colorado
Background on what I am trying here. Wanting to drop car 1.5” all the way around and after using the ingalls camber kit I am not happy with it. I am moving on to trying the SPC adjustable ball joints. I am not too thrilled about going with the Megan Racing arms since I want it to still have a “stock” appearance when looking at parts on the vehicle.
So I am trying to solve the front camber issue when dropping a car and am running into some problems with finding ones that I feel comfortable with using. Attached the photos of each side control arm with two different brands. The first has a version I am MUCH more comfortable with since the second material goes all the way around the ball joint area where as BOTH of the second set it only goes to a certain point.
Here is the other side where neither brand control arm has a second layer of material that goes all the way around the ball joint.
Ok, so what I am worried about is the material is too thin on the ones without the second layer or material and bending the control arm/spc ball joints after some time.
Is this a valid concern or should it be enough still? I really couldn’t find a solid review of them on here or online. It’s pretty mixed.
I know that even with the double material I still have to grind some material off so the ball joint goes to its full movement of adjustment but I am still way more comfortable with that than having that single layer there. I also don’t want to keep buying multiple control arms to see which ones have more material. Bought two brands and unless someone knows for sure of one that does have the second layer I am done. The pics of the lower set in the photo online HAD the second layer but when it arrived it
as it now becomes the weak point
