Street Build from GS to GST
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Drivetrain
FWD
Build Type
  1. Street
MHI TD05-18G turbo + open dump pipe+ FP exhaust manifold- all these are black ceramic coated, FP cast aluminium intake pipe, Mishimoto FMIC & oil cooler & radiator, Walbro 255 ( GSS342 ) fuel pump, aftermarket fuel pressure regulator, Mishimoto oil catch can, Zaklee transparent timing upper cover, Fluidampr crank pulley
Mods-Engine
NPR pistons, stock 2G OEM Mitsu GST rods, HKS fine tuning timing belt and HKS adjustable cam gears
Mods-EMS & Logging
DSMLink V3, AEM boost gauge , AEM wideband A/f, Autometer oil press - oil temp - water temp
Mods-Drivetrain
XTD stage 3 full clutch kit, with stock F5M31 transmission
EBC turbo groove brake discs, ( 276mm),Ferodo DS2500 pads, H&R lowering springs ( -35mm ), OEM Mazda RX-8 alloy wheels, 3 set. ( white-with winter tires 225/40 R18, Gunmetal Gray- with summer tires 245/40 R18 Michelin Pilot Sport 4 , black - with training tires 245/40 R18 ), Goodridge brake hoses, front and rear upper tower struts.
Dyno HP
310 whp
  • Like
Reactions: BLACK'98DSM
cosmicDSM
More in 2G DSM
Share this Vehicle
