Kryndon
- 962
- 622
- Jan 10, 2014
Bulgaria,
Europe
So I've got the book open, doing everything properly. I lined up all the marks, I kept the pin in the tensioner, I tensioned the pulley by using needlenose pliers and pulling it CCW so both small holes point down and are horizontal (as per FSM). While holding it to that position, I torqued the pulley bolt, threaded in the special tool just to apply slight pressure on the tensioner rod and removed the pin. I slowly unthreaded the tool and let the tensioner rest in it's operating position. I rotated the engine 6 times as instructed, and everything lined up perfectly. The belt tension feels just right (I have a habit of touching the belt while on the car).
However, the rod seems to be way more extended than what the FSM calls for. It suggests rod gap anywhere between 3.8 and 4.5mm, whereas I got 8.4mm as a final resting gap. The tensioner is not new, only the timing belt is. All the other timing components I am reusing because they only have 12k miles on them when I bought them brand new. I cannot remember if I bought an OEM tensioner, but I think I got some other brand. Could different brands have different shapes and lengths, which could throw my measurement off? Here's a quick vid showing all my timing marks:
And here's a diagram of my tensioner's dimensions, as well as before/after side by side pics of the timing marks after doing 6 full engine revolutions.
