F5M33 transmission input shaft bearing part#
jmbond47
5
Sep 22, 2023
burlingtion, ON, Canada
I am currently in the process of replacing my leaking input shaft seal and replacing the input shaft bearing right behind the seal but I have run into a little bit of a miss match with part numbers. the part number for the tapered bearing on the input shaft right now is HR32205 and shows up as a wheel bearing when looking it up. but on rock auto and other sights the replacement part number for that bering is BT1993 and both parts have different dimensions. So i am unsure as of what part number to go with at the moment any help would be appreciated. thank you!
Any reason to not just get an OEM part? Looks like it’s ~$25. Part number MD732314.
Being in Canada may change things for you.
Here is one site that lists them that low. eBay also has options but the low cost ones show out of stock. The ones “in-stock” on eBay show about $50 which still isn’t terrible, IMO.
Just contact a bearing supplier or buy a HR32205 bearing on amazon, or if you have a mitsu dealer, it is MD732314. The input shaft outer bearing is obsolete, MD726235, but that one typically is low wear unless you have pitting of the surface of the bearings from excessive end play and debris in your gearbox from dirty gear oil.
If you need to get the input shaft seal, it is MD741818.
¿Alguna razón para no comprar una pieza OEM? Parece que cuesta unos $25. Número de pieza: MD732314.
Podrías facilitarme el número de parte de los anillos sincronizadores para 1.ª y 2.ª de una sola pieza de 39 dientes para la F5M33 de 1G. Gracias
Google Translate:
Could you please provide me with the part numbers for the 39-tooth one-piece 1st and 2nd gear synchronizer rings for the 1G F5M33? Thanks.
