dsm-onster
DSM Wiseman
- 8,592
- 131
- Jul 11, 2004
Bloxom,
Virginia
Thats fine, I pulled that flow rate from were the boost est. and were my 3 bar meet which to my understanding is the most accuarate. I know my air flow is off in some other places but its not like i'm making this shit up for some glorified reason.
Ok just to add I polished the inside of the compressor housing and port matched the outlet to match the gasket. Do you think that would help it flow better?
A little bit...
Wow! I didn't look at the 70-90 times. Are you running blowthru? You've checked for boost leaks surely . . . Mid to upper 300s is very good for the evo3 16g.
All the 16Gs do about the same at around 20 psi. I've seen 36 lbs/min with my small 16g at 17-18 psi. And fp2x cams.
I need to do a few pulls and let it rev higher to get a good estimation on time.
Doesn't seem to help though, keep breaking built trannies.
