Evo 8 ECU In 2g Works!!
I'm not running it, it is generally considered a PITA because it can change the A/F ratio by up to 1 point and wreak havoc on you tune. I would suggest leaving it off.
+1
On every evo I tuned, I turned off the lean spool.
Awesome to be getting this much attention in here.
Also super great that I can finally post in these sections now.
I've been running the Evo ECU on and off now since december when this thread was only a page or two long. One thing that I still haven't been able to figure out is the interchangibility of ROMs. I have 941500017 and have also had the crank and cam angle sensor issue. What kind of options do I have for changing to other roms?
Any evo 8 rom can be loading into your Evo ECU. here is some post from this thread, describing use of diferent ROMs
http://www.dsmtuners.com/forums/tun...21515-evo-8-ecu-2g-works-9.html#post151763048
http://www.dsmtuners.com/forums/tun...1515-evo-8-ecu-2g-works-12.html#post151806193
Just download a different rom image then upload it to your ecu after making the necessary changes. 96530006 seems to be the favorite. Hardware-wise I think all 4plug evo8 ecus are identical or at least very similar.
hey is it me or are the people @ evoscan hard to reach ive email em a few time and sent them copies of my receipt showing that i bought evoscan but my comp crashed and now i dnt have the serial # to use.. any help?
Its only one guy, hamish. Hes very busy, as I believe he has a regular job, in addition to evoscan. He should get back to you within a week. How long has it been?
umm like 4 days....LOL. mitsulogger is kool but wen i open it and have to set the injector cc and dead time and latency ... i really have no clue what to put since im running my stock 450cc... so yea... i dont want to use it with wrong data and it gives me funky logs...
i haven't used mitsulogger myself but you should just be able to open ecu flash and look at the tables for the injector deadtime, latence, and size and enter exactly what you have into mitsulogger.
Try to message him on EvolutionM.net. His username is Evo4mad. evolutionm.net - View Profile: evo4mad
My 1.3 cable has been dead for about a month now (so haven't been able to try out the new SD patch), anyone know where i can get it inspected/fixed?
I got it earlier this year probably like feb. I tried emailing Hamish over a month ago but haven't gotten any reply. Not really sure what else i can do.
Send another support ticket as well. I sent one for my cousin before, and he had to end up sending it a second time, then he heard back right away. Give a day & a half or two days for a response and try again if you don't hear back. I'm sure he's quite busy with Evo stuff, and I would bet he also has a real job or owns an electronics or car business or something. He took care of my cousin well after finally getting a hold of him.
Ill try sending out another ticket tomorrow, hopefully he can help me out because it sucks to not be able to flash my old rom back in.
Sweet, he replied to my ticket so now im shipping off my cable monday and hopefully getting a replacement one soon.
So, does someone feel like posting up a base rom (and xml) for a 2g with the necessary stuff for stock 450cc injectors, 2g MAF, and any other odd ball things to get it to run on a 2g?
Then, people can have a base to work with. I'm getting my Evo 8 ECU sometime this week (mailed Sat) and I don't have much time for downtime since this is my DD.
What rom seems to be working best on the 97's?
And hediki12, I think you bought that ECU right before me. From AllYouCanTiff on evolutionm.net right? He sold it 3 hours before I PM'd him. I ended up getting mine for $125 shipped.
You might as well start with a 96530006, at least you shouldn't have the CEL's for cam & crank sensors then. There are a good amount of mods & xml additions with this rom, and it's now considered a pretty much universal rom for Evo 8 ECU's. Go with the tephramod rom while you're at it even if you're not using the mods, since it's the easy way to be able to log load.
I have the tephra v5.10 96530006 rom saved on my computer but I can't find the MAF scaling stuff from step 3 of the first post listed in ECUFlash.
  • I adjusted the injector scaling to 450 and the injector latency to what was suggested.
  • Turned lean spool off by setting start and stop RPM to 9000.
  • Disabled the immobilizer by setting periphery bit 0 hex to 56D2.
Anything else?
Without the ECU here yet, I can't flash it to try it yet, but I was just wanting to get a rom ready. I'm heading out of town this weekend for the 4th, so this might not happen until the week after.
Anything else?
Have you made sure that you have the user level set to developer?
Will a evo8 ecu work with a 92 vr4 galant.
They are very similar, basically 1g/2g/vr4 should work just fine.
ECU has everything to support 4G63 Turbo engine, if you want to take care of small MAF/knock/EGR/Evap/CAS/CAM sensor issues...
Although 97/98/99 2G DSM ECU might be easier to start with.
