miguelmcv
Supporting Member
- 2,718
- 261
- May 3, 2009
Fresno,
California
Nice to hear that, any pics of the mbc and boster.
I would ike to see the finish look.
I got the car off the jackstands today, it starts, idles, and it stops like an Evo now.![]()
To anyone that has done the Evo brake conversion, or any brake upgrade for that matter, I HIGHLY recommend installing a 3g 9.75" brake booster and 17/16" brake master cylinder on your 2g, you won't regret it.
Now I'll be able to beat an Evo to the finish line and stop faster, too!
[B][U]Parts[/U][/B]
___ Wheels that will clear these brakes, use EvoM and research fitment if you aren't sure
___ Evo VIII/IX Brembo calipers and assoc. hardware (front & rear)
[B][COLOR="red"]***If, for whatever reason, the calipers you bought didn't have the pins and anti-squeal
springs you'll also need to purchase these.***[/COLOR][/B]
___ [COLOR="red"]Pins and anti-squeal springs (front) [B]MR475935[/B][/COLOR]
___ [COLOR="Red"]Pins and anti-squeal springs (rear) [B]MR475936[/B][/COLOR]
___ Evo VIII/IX rotors (front & rear)
___ Evo VIII/IX brake pads (front & rear)
___ kmv caliper brackets and assoc. hardware
___ SS brake lines, stock DSM or Evo since both will work
___ 3g 8+9 (9.75") brake booster, any model
___ 3g 17/16" (1.06") brake master cylinder, any model
___ -3AN SS line, need approx. 32" to 34"
___ -3AN to M10 x 1.0 adapter fittings, you'll need two
___ M10 x 1.5 (25mm long) bolts, you'll need four
___ M10 flat washer and lock washer, you'll need four of each
[U]Special Tools[/U]
___ Air compressor
___ Die grinder
___ Egg shape double carbide bit
___ M14 x 1.5 tap
From the 3g FSM.
Not sure if this is a strictly "KMV" bracket brembo conversion, but I got mine done while my car was down. I used JDM Galant knuckles and I repainted them.
Pics:
Now to figure out how to get rid of that annoying "slow brake squeal."
You need proper lug nuts. From the looks of it, you have aftermarket "tuner" lug nuts, when you should be using an OEM style lug nut.
As for the noise... Are you using the factory brembo brake pad shims?
Yea I'm going to buy new lugs here soon...they don't quite seat correctly.
Not 100% sure on the shims.
I have researched the brake noise issue. Is it not a common problem among Evo drivers? I have read numerous threads...none with a 100% cure all...seems to be case by case.
You need to bed the brakes in to help eliminate the low speed brake squeal. When I first installed Hawk HPS pads on my Evo I had this issue. I re-read the bedding in instructions on the side of the Hawk pads box and performed as instructed and haven't had a problem since. This only works if all the hardware was installed correctly.
Josh
These are the factory Brembo brake shims.
Majority of Evo owners over look the importance of these shims. In my experience, any time I didn't use these shims I had noise issues. When you install pads without these shims, they vibrate (when applying brakes) against the pistons in the calipers. The shims also act as a heat barrier for the piston dust boots.
A lot of aftermarket pads have a shim attached to the back. I tried out many different pads, looking for the perfect pads for my application. Once I did find my ideal pad (Feredos 2500) I noticed they didn't have a shim already attached to the back of the pad. After shim install and proper bedding of the pad, noise was nonexistence.
Also take into consideration that every pad is made up of different compounds. Different pads have different priorities.
^ listen to this guy. Bedding is key.
As requested through a PM, below is a "shopping list" of parts/tools you'll need to do the Evo VIII/IX Brembo brake swap along with upgrading the hydraulics; keep in mind this is using the kmv bracket to adapt the front calipers to fit the 2g knuckle.
Code:[B][U]Parts[/U][/B] ___ Wheels that will clear these brakes, use EvoM and research fitment if you aren't sure ___ Evo VIII/IX Brembo calipers and assoc. hardware (front & rear) [B][COLOR="red"]***If, for whatever reason, the calipers you bought didn't have the pins and anti-squeal springs you'll also need to purchase these.***[/COLOR][/B] ___ [COLOR="red"]Pins and anti-squeal springs (front) [B]MR475935[/B][/COLOR] ___ [COLOR="Red"]Pins and anti-squeal springs (rear) [B]MR475936[/B][/COLOR] ___ Evo VIII/IX rotors (front & rear) ___ Evo VIII/IX brake pads (front & rear) ___ kmv caliper brackets and assoc. hardware ___ SS brake lines, stock DSM or Evo since both will work ___ 3g 8+9 (9.75") brake booster, any model ___ 3g 17/16" (1.06") brake master cylinder, any model ___ -3AN SS line, need approx. 32" to 34" ___ -3AN to M10 x 1.0 adapter fittings, you'll need two ___ M10 x 1.5 (25mm long) bolts, you'll need four ___ M10 flat washer and lock washer, you'll need four of each [U]Special Tools[/U] ___ Air compressor ___ Die grinder ___ Egg shape double carbide bit ___ M14 x 1.5 tap
Everything in the list is what's necessary to do the swap, installing dust shields isn't required.Shouldn't dust shields be a part of this list?
Because the bolt that threads into the KMV bracket also needs threaded into the knuckle.
That's what I'm confused about because the bolt goes fine through the KMV bracket without being tapped.
