Shooty
- 71
- 26
- Jul 1, 2012
Rimouski,
QC, Canada
Hi everyone
My friend bought an Evo 1 a long time ago and decided to make it run lately. The car probably spend most of it's last years in a barn so it's going to be a long run to make it beautiful again!
The car is completely stock except for the fuel pump. The reason is simple, rust had eaten away the tank, sending unit, pump over time so it had a Bosch 044 installed on a temporary fuel cell
To makes things quick and simple, it runs so rough it sounds like it's not running on all fours. We played around with some fresh plugs and we also tried with a coil on plug setup but it still feels so wrong.
We called it for the night
I wanted to have some ideas from other members here just to brainstorm about this:
Could it be the pump being so big that it is overflowing the capacity of the stock fuel pressure regulator?
Maybe the injector are being dirty and they would need a good clean along with the replacement of the fuel filter?
Either way, thank you for checking this post out!
