EVAP Canister Replacement (3g for 2g...)
BLACK'98DSM
Moderator
5,522
3,057
Feb 9, 2019
Alabama
I have come to the conclusion that my EVAP canister is bad for sure. I tried the hoses and connectors, all for a waste of time. There are currently no 2g eclipse' at my local junkyard, but there are a few 3g's (02, 03, 04). I was just wondering if anyone knew whether or not the EVAP canister was the same or even similar so that I could make it work? I'm trying this first because a new one runs me at least $200.
As far as I can tell, it was only available in 2G Eclipses and some Dodge cars, like the Sebring or Avenger (1998-2000). Are there any of those in the junkyards? If you can live with the CEL, I agree that it might be best to remove the whole system. In my experience, problems with the EVAP system are some of the most difficult to track and definitively resolve.
what makes you think your EVAP canister is bad
My check engine light was on, and the code said it was the evap system. I've tried cleaning out the hoses and electrical connectors so I guess that means it's the canister.
The earliest Avenger they have is '08 and the earliest Sebring they have is '01.
I'm curious why you think your EVAP cansiter is definitely bad. That code is for the vent solenoid. The FSM says it's caused by a failed solenoid, faulty wiring, a clogged vacuum hose, or a bad PCM. Personally, I'd try triple checking all the vacuum lines before replacing parts. I wouldn't be surprised to find a leak in a 21 year old car.
If the solenoid needs to be replaced, I believe 4669306AB, 04891423AB or 04891423AB might be the right part numbers. They're just as expensive as the EVAP canister brand new, but they were used in a bunch of Chrysler vehicles from the late 90's through 2000 (Sebrings, Avengers, Talons, Neons, etc.).
Ok, #10 on the diagram is the part that I think is bad. I was told by another that that was the canister, under the bumper. I guess that's the solenoid then. So in that case, where is the canister located?
the purge solenoid is under the bumper. everything else is right behind the gas tank
you can see it
I'm currently using all 4 jackstands on my Mustang, so I'll have to look into this later. Thx for the vid
For anyone wondering: These are the list of cars with the same or similar EVAP systems.
hit me up if you need any parts.
i pulled all the evap system off my 98 like 15 years ago.
Parts have been taking up space in my garage ever since.
I'm not sure that's completely accurate. To my knowledge, the 4Gxx models (including the Spyder) used different part numbers for their canisters, etc. Maybe they fit and work the same, though.
I'd rather not have it on all the time. I need it to come on only when something is actually wrong. But in that case, i need this evap **** fixed
It was the purge solenoid. The idiot before me put the 2 hoses in the opposite places, so I switched those back. Also one of the hoses didn't have a clamp so I put one on. The connector was also extremely greasy so I wiped it down and tightly connected it. CHECK ENGINE LIGHT IS OFFICIALLY OFF
Yes, and thanks for your help. I thought I knew everything there was to know about eclipse' until this came about. I'm glad to have this experience now though.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
