eprom ECU looks like it's leaking??
zeekster777
523
Dec 31, 2009
valley center, California
I ordered a ECU from some one, in the classifieds, and it looks like the caps are leaking. could anybody help me with some pictures of what it might look like. can any body describe what it is I should look 4. to me it looks like one of the caps has brownish black crusty syrup leaking out and across the rest of the board
Yes its leaking at the caps, simple as that, shouldt have the stuff leaking out of the they have caps for those, have them replaced.
there you go that simple
Really it's not thought, You maybe removing alot more then just caps(like in the link above) to get to all the acid off the board even if it's not showing signs of corrosion it can continue to corrode the components if all of it's not neutralized.
He's a few more pics to give you an Idea of what your looking at 1st pic is a 2g board but has some good and bad parts pointed out on it.2nd is what you want yours to look like.
thanks, is there a place to get the caps like radio shack or ????
i found them on ebay thanks, but i think i can get them just as easy at radio shack? just wanted to know if i should look for a better kind of cap, like a upgrade? does any one have some # i should ask for when i go looking.
I'm not sure if you'll find them their but they are,
47µF @ 50V, 22µF @ 50V , 100µF @ 25V you can up either the voltage rating or the capacitance of the capacitor if you want. For example, instead of 50V capacitors, you could use 63V capacitors. You just have to make sure that the capacitor is radial (IE leads coming out of the bottom, Not axial) and that it will fit.
Also make sure you use electical contact cleaner before hand on the board before replacing them and be careful so you don't spread the electrolyte in the process of cleaning it off...
Alot of people don't relize the caps just start the problem and fixing them without cleaning the board properly along with fixing other damage that maybe hard to see is just asking for trouble down the road... Just look for ANY other damage and fix it as well...
yes they didnt have them there at the shack but i had to go see 4 my self. so ebay it is that sucks i dont have a bank or credit card or pay pal ugh
this is what my ecu looks like
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/JyH9hNrU5Q4mMifjT8KA16L-ZqgQeKq3VQAQdRluw4E?feat=embedwebsite"><img src="http://lh4.ggpht.com/_5gb07DlBZOE/TQaNr6QO7WI/AAAAAAAAChc/ObLvc4YQskM/s144/IMG_20101213_131330.jpg" height="108" width="144" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/zeekster7777/DropBox?authkey=Gv1sRgCLf2rYm_jPPoPw&feat=embedwebsite">Drop Box</a></td></tr></table>
today my caps came in the mail. I took the old ones out cleaned it up and put the new ones in. Very nice it woks good. thanks 4 all the help>>>>
Its so funny I have a had a no spark issue been installing all of the new parts came to the last solution ecu, and sure and crap the caps were leaking and burned some of the components did not look good at all. so now i am waiting on my new ecu to come the waiting game sucks. Just got done finding that out and then i found this post with pics of bad caps and that was my insurnace mine is junk but even worst.
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
