Engine vibration!!
Louis Gibson
Jun 23, 2019
Tillamook, Oregon
I’m in dire need of help as I am confused to what’s wrong with my eclipse
97 eclipse GST
Has a 7 bolt 4g63t with NO crankwalk (trust me)
Engine mounts are secured and in good shape
Has newer clutch
My bro and I just tightened the timing belt on the eclipse and got all the timing marks aligned and got everything put back together only to figure out that the car now has a vibration to it when in idle, high rpm, low rpm, doesn’t matter.... to best describe the vibration, it feels like you’re sitting in a massage chair... the engine runs amazing.... it takes whatever I throw at it performance wise.... the car starts like a champ and drives like a champ...... the vibration is especially bad when the car decelerates... i
This is very confusing and I’m not sure where to go from here. Has anybody experienced this problem with their car?
(Again.... never had this problem UNTIL we tightened the tension on the timing belt. (And yes we made sure that the balance shaft pulley was aligned up with the rest of the system.))
I’m not sure no.... all the timing marks aligned up to my best knowledge...
If you took the belt off you probably have the belt out of phase. That it you think yiu have the marks right and you dont. Take it apart and do it again.
Yeah the belt got taken off.....
Basically what we did is aligned the cam wheels (the marks facing each other while being horizontally aligned with the top of the cylinder head) and aligned the crankshaft to its mark and oil pump to its mark.... we never took the belt off of the balance shaft gear..... that’s all we did
Here you go. There's also a bolt one the back of the motor you can remove and install a screw driver to see if the balancer is in the correct position.
Yes post 8 above shows the easy way to tell. Also the red paragraph of step 24 here: http://www.vfaq.com/mods/timingbelt-2G.html.
I'm going to add this. The gravity method does not work if the seals are brand new so plan ahead if that were the case. Also I've used the gravity method dozens of times. Last time I removed a bolt to check manually was probably...1994?
