Engine vibration
94gsDOHCHAP
Feb 19, 2004
Coral Springs, Florida
94 GS DOHC N/T need help with wierd engine vibration. Most pronounced when coasting through a left turn only, especially if clutch is in and engine is at idle. Vibration only exists when moving and turning left. Disappears with any partial return of steering to right. Does not occur turning wheels at stop. Only mildly noticable with car in gear but beginning to notice it more.
Recent repairs include new motor mounts and PS Pump, new tires all around and alignment done. Shop indicated no suspension or steering problems but I'm not 100% sure. Also having choppy idle problem. Don't think this would be a crankwalk issue but??
bty I'm original owner with 170k miles. Changed out the crankshaft pulley 3-4 years ago as it was seperating. Think I remember similar symptoms. Going to pull the belts off to see if its only the pulley? I know crankwalk can happen but seems unusual for the Non Turbo GS.
