Resolved Engine timing mount bolt size
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
I'm not sure if I'm not using the correct terminology, but I cannot find the size of the these bolts under the link that gives all the sizes. It's for a 2g mount and I'm using a 6 bolt tensioner arm, thanks in advance!
From left to right, the first bolt is an M10x22mm length with sealant, the next two are M10x22mm lengths, and the last where the arm pivots is an M8x16mm length.
edit: my bad, the CAPS showed "8x22" which I confused for meaning an M8 bolt, which is not the case. They're M10s like Mello said.
From left to right, the first bolt is an M8x22mm length with sealant, the next two are M8x22mm lengths
Are you sure these are M8. I think these are M10x 22 (1ea MD194109 w/sealant & 2ea MD241281). Agree the last is M8 x 16 (MD182537). These are 2G numbers. Hopefully others chime in.
1G 6 bolt:
M8x1.25x16 for tensioner arm (MF241251).
M10x1.25x22 and M10x1.25x25 for bracket (MF241281 and MF241282).
1G 7 bolt:
M10x1.25x22 and M10x1.25x25 for bracket (MD194109 and MF241282).
2G:
M10x1.25x22 for bracket (MD194109 and Two MF241281).
1G 6 bolt:
1G 7 bolt:
2G:
So I'm assuming I use the 2g size even though I'm using a 6 bolt block? I'm doing the 7 bolt head/6 bolt block combo
