2G Engine sounds done
kidmet
Supporting Member
217
21
Jul 23, 2012
Aurora, Colorado
Engine started making this noise, now I'm not really sure where to go from here. Any help diagnosing would be great. Probably drop the oil pan shortly. Timing is on. Head components are new, new lifters that were bled.
I did find the flex plate to be loose. Like all the bolts came out half a turn (for convo sake) and the flex plate will wiggle back and forth and hit the bolts (making a metal on metal striking sound)
So the cause of metal contact sound was the flexplate bolts.
Did you inspect the coils, spark plug cables etc etc, too? You don't see any physical damages on those?
Checked coils and spark plug wires. No damage at all. Checked starter, good. All grounds were in good shape.
The noise wasn't the bolts rubbing anything but the flex plate hitting the bolts, or so I hypothesize.
Well yeah I meant the bolts were loose. It's a common issue.
I am really concerned about the sparks on the engine. I hope that is just some sort of camera lens noise.
I’m no expert but it sounds like a blown throw out bearing
upon listening again I’m almost certain
start it and push the clutch in and out and listen to what happens
Considering this is an auto car (see above) that seems unlikely. :)
I also tack weld the flex plate bolts now as well. I have seen more than my fair share back out. Not what we like to see at 10,000rpm and 1000hp.
I spent 13 hours going through this car today. Among the many issues I found, no offense Sean, this turned out it was both the flex plate and torque converter bolts had come loose. I have it running very well now and will be tuning it tomorrow. I am also putting it on the Dyno on Monday as well.
None taken! Thanks for jumping in and saving me! Hahaha
Well as you see he has clearly stated that it's solved above, so I still can't get this situation. But if it runs well now, that's a good news anyways.
