ECMlink Engine revs and immediately dies. Wont idle after 1600cc injector install Log included
Not sure if I've helped you before or not. I know that's the SD map I've created a good while back though. Tried giving it some throttle to keep it going until it warms up a bit at least? Might need a biss adjustment but can't tell because it's not running long enough. Give it some gas to help it out and then go from there. Don't see anything jumping out at me that looks wrong in the log though.
What's the best way to adjust the BISS to normal operation? It seems like it idles good until it warms up and then dies if I give it any throttle or put it into gear and as soon as I hit the throttle to take off it dies and doesn't want to stay running after that. Any suggestions?
I didn't say while giving it has. Said while in gear. Huge difference. And get better injectors. Those are like the worst ever.
Just delete the resistor box on the firewall and install the delete plug. Can make one using the resistor box you just deleted if the injectors don't come with one so don't throw it away. Then the rest is just setting it up on ecmlink. My 2150cc injectors run just like stock. Flow tons more fuel.
Only downside to them is price. But saves you money after going through 10 sets of injectors. Last ones you'll need to buy depending on how large you go.
Yup.
For TPS, start a log then push the pedal all the way down and release. Then right click on the log and select TPS adjust.
ISC position - Get it to operating temp and with no load and fan off, adjust the BISS to get the isc to 30.
Airflowperrev - increase the cell in SD idle area.
