Ecu fried burnt let me hear what ya thank
Big Mo
Aug 15, 2020
carson, California
What do yall think do you call this fried or just dirty havin some funky car issues and think i found a good reason
I see the capacitor is leaking. Send it to ECMTuning or someone for repair or buy capacitors and ask a local shop to replace.
The board has a coating that should have kept it being damaged. Clean the electrolyte off the board with some 91% Isopropyl Alcohol and q-tips. Make sure and check the other 3 caps for leakage as well.
If you know how to solder and desolder (or know somebody that can), you can get a set of caps from RTM for like $2 or $3
https://www.rtmracing.com/xcart/product.php?productid=18592
just make sure you carefully scrape off the coating before trying to solder.
What IS the coating they put on the boards? Had to remove all mine for a fix and wanted to reapply it.
If there's damage to surface-mounted parts it's going to be a challenge to fix. You need a tiny soldering iron tip, decent vision, a good magnifying glass, and very steady hands. I've done it in different contexts (laptop), but it's not easy.
