HaveBlue83
- 660
- 245
- Feb 10, 2009
Wrightsville,
Pennsylvania
Here's what I have:
-95 Talon TSi AWD
-V3 DSMlink less than 1yr old. bought NEW
-Socketed EPROM by ECMtuning
-V3 cable confirmed LED lights up upon connection and when trying to connect to ECU
-Pin 1 re-routed straight to pin 56 at ECU to eliminate any issues with harness
-Pin 7 re-routed straight to pin 62 at ECU to eliminate any issues with harness
-OBD port cleaned with MAF cleaner and blown out with compressed air, no loose pins from what I can tell.
-macbook running Bootcamp to windows XP. mac side will NOT run ECMlink, it force quits immediately. I have tried other Windows Native laptops with the same results as below.
MY ERROR:
COM6: Trying to connect
COM6: No response received!
LOG MSG: Action raised exception
a pop-up message comes up "No response received!"
COM port5 is sometimes available but does not connect either. the USB cable is on COM port 6 AFAIK.
I have send my cable back and have been given another one. I have send my ECU back and it has been verified that it is OK and works. The ECU is currently IN my car, and the car runs, drives, boosts, etc within stock map parameters.
I have emailed Tom from ECM tuning in good moods and bad moods about this and he told me the cable and ECU are verified OK.
I took this to Karl Pritz (owner of KP Tuning in Philly) last night and he has NEVER had an issue with a V3 cable on a DSM in this manner. He was totally miffed on this issue. He used his tuning computer and tried for 45min while the car was ON to connect and it would not. He just tuned a 2g 2 weeks ago using his setup with no issues. he re-installed ECMlink, checked all drivers, everything to no avail.
I am about as pissed off as I can possibly be without doing physical harm to my vehicle.
I bought the car BONE STOCK from an adult that was the second owner. there were NO splices on the factory wiring. nothing molested.
please god does anyone have some insight???????? I have scoured the wikki and have done everything listed to check.
-95 Talon TSi AWD
MY ERROR:
