2G Eclipse 2Ga door caps - (not Talon 2Ga door caps)
Justin DuBois
DSM Wiseman
3,401
3,375
Aug 15, 2019
Oakland, California
I did not realize that the door caps are in fact different. I was happy to find any door caps in the universe on e-bay, and got a nice pair from a Talon, and only now painted and installed do I see that the Talon parts don't flair out as wide as the Eclipse part.
Here is the original:
The mixed result is pretty cool, but I am interested to locate the correct part for this body style.
Any thoughts? More e-bay? Any other sources?
@Sirius1995 did me a solid and looked at his 2G stuff, but no luck.
The part at the bottom of the door is year specific, and don't mix and match.
Talon twisty skirt has its own door cap ( about 1" thick )
Eclipse 2Gb has a thin door cap (about 1" thick )
Ecliipse 2Ga has a thick door cap (about 2" thick)
Each model has their own matching side skirts.
So I'm still in the hunt. I put a wanted add up in the classifies as well.
Looking for 2" thick eclipse door caps - any color.
Give these a try. I've had good luck with amayama. Expensive but they have parts I couldn't find anywhere else. Never used nengun but seems legit.
This is a 2Ga door cap with the matching side skirts: (not well attached i think)
So fragile - RIP 2Ga door caps:
These didn’t survive. 😢
Still looking.
Justin
This is going to be an issue for 2g guys. Someone should reproduce these with better quantity plastic.
Wonder if using a fishing line to remove the double sided tape and getting the tabs off from the inside would save them?
These died in shipping - but yes. The plastic is so brittle, it would be better if these were re-made.
Im searching as well, I may try to restore mine as I have one crack and one broke clean in half and looks ok lined up, but all the clips broke off as well is the issue. I found this but shows a wide year rtange and may be specific to their skirts?
$80 + 150 handing charge is out there though
Yeah, I think VIS has 1”thick talon door caps, also 97-99 eclipse are 1”. I’ve yet to find aftermarket 2” thick eclipse for 95-96 door caps.
refurbished stock parts is all we can do for now
make a mold and fill it with flex seal LOL, i would have never tried to rem ove these if I knew they would crumble. I am going to wrap them so i may epoxy them and wrap, well see how it goes
They dont really crumble, its almost like the urethane blend had too much hardener in it compared to the 97-99 eclipse pieces.
They crack and the tabs on the back break off immediately. The only way to really ensure they dont brake during removal would be to remove the interior door panels and pop the rivets out from the back side.
My passengers side is still just fine, but the drivers side was installed slightly tilted at the factory
Everyone says just to convert it to the newer style, not gonna happen. Technically this is the rarer body style 🤣
