95 Door Caps
Are you talking the moulding that sits alongside the bottom of the door? Or are you talking about the piece of the sideskirt that wraps around the fender? (I've heard those referred to as door caps as well)
If they are falling off; the sticky tape is failing or the little panel clips are worn out. Chances are that's all you'll need to fix it.
at the bottom of the door, and i know that but its cracked to so i figured i just by new ones. Im NOT talking about the side skirts that wrap around into the wheel area
Oh, ok.. if; its cracked then yeah, grab some new or good used ones. It would be considered a moulding in most parts catalogs.
EDIT: wait.. my bad, I think it's the "ground effect" piece in the catalog.
Alright, but is that a door cap in the first pic i posted, even though they call it a door mldg or something
  • Wanted 6 bolt NT water pipe
    • chrisman287
