turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
I hope you are not running around at 18:1 on e85 on a wbo2 set up for gasoline, and that your lean reading was just an accident like mine. If so, you need to back it down to 11.5-12:1 or you are going to melt something.
It does not matter if it's set to gasoline, it took me a few to realize this when explained, but teh instructions that come with the AEM uego helped me figure it out.
The AFR numbers is just a display based off of the actual "Lambda" reading which is the same for all fuels as it's a percentage above and below stoich but accurate all teh way through on all fuels.
11.5:1 on gas when displayed is 0.790 lambda reading, this equalls the same as 7.11:1 on ethanol, but the reading just comes out as a gasoline reading of 11.56:1..... Even at cruising where you need ~ 14.7:1 the gasoline AFR matches up with the same lambda voltage as needed on E85 i.e... 14.7:1 = 1.0 lambda which = 9:1 on E85 (also the "stoich" area for that fuel... I hpe that's not too complicated, but in short terms, you can use gasoline readings and targets to tune your E85, just the actual ratio of what's going in will be different than what's displayed, but still will be your correct target AFR.
