dsm link ?
you can use the software part on any car so long as you have the right version. And you can swap the ECU to any car, what your paying for is for the ECU to be chipped, that chip is attached to the board. So if you put your ECU in another 2g it will work fine. As for a SAFC, I dont think it even comes close to ECMLink IMHO.
I would stay away from SAFC they tend to make DSMs run like ass unless you know exactly what you are doing with it. Your gonna spend a lot of time and headache effin with it. DSMLink. Use that.
DSMchips are preburned chips that cannot be modified. The companies offers many different chips that will control your fuel for you and you can customize the chip to extent then he makes the chip to your specs and mods your ecu for you. . Its link tuning for dummies.
what would you suggest?
DSMLink all the way, dont go lite either you will hate it. Theres a lot of support with it and its pretty simple once you spend some time with it. Its fully customizable so you can upgrade in the future you fuel or air system and its the most comprehensive logging and data stream to see exactly what you car is doing. Its the only product that the actual creator will answer your questions about. A+ for customer service. Get link and never look back!
If you dont have major goals or know you will never upgrade or change a thing, you can gamble with a chip but the settings are set for life, no tweaking :( but its less cost
