dsm link help???
motoracer1125
Apr 21, 2009
mayfield, Pennsylvania
hey guys i live in scranton pa and was wondering if anyone near me has some knowlege about dsm like i have a 92 talon awd and i have a v 2.5 link and for the life of me i cant figure out how to use it i printed out all the write up and followed them step by step and i cant get the computer to pick up any kind of sgnal from the car i keep getting an error message, so if anyone is near by me i can give you some money for gas if you could help me out??? 570-309-5664 Joe
ok someone called me tonight and gave me a good idea what im doing wrong i think i just need to change my communication port on the dsm link program i will try tmmr and let you guys know how it works out thanks
I just went through this with a new laptop.
Turn the ignition on.
Plug the car into the laptop, with DSMLink closed.
Start-> My Computer (right click) ->Properties->Hardware->Device Manager->Ports.
You'll see something like Keyspan (Com 4), or whatever brand of adapter you're using if you're like most of us and using USB Obviously you'll need to install a driver for the adapter if using USB.
Open dsmlink. Go to Edit-> Options -> Configure, and select the port that it said in device manager (Com 4 in the example).
Click OK
Enjoy.
Correctly specified by bigbeans, you need to identify the port which is being assigned to keyspan USB-Serial adapter first. Use that specific port to connect to DSMlink
i had the same problem.
easy fix, exzactly... you have to choose the correct usb port in the program, before it will work.
it took me a week to realize this same problem
