do I need to tune
95tale
110
Jul 26, 2013
hamersville, Ohio
Ok im doing a turbo swap in my non turbo 93 eclipse gs and I was wondering if I would need to tune I have all stock parts only plan on pushing like 10 to 14 psi
Even if I want to put a turbo 4g63 engine in my car I have fmic, greedy bov, 14b turbo, all oil and coolant lines, turbo maf, turbo ecu, turbo fuel pump, 450cc injectors, fuel injector resistor pack, knock sensor, and a 4g63t engine so would I still need a tune if im using a turbo engine
Oh with all that on stock boost it will be fine. I think thats everything.
I still recommend ecmlink but you dont need it.
Yea I plan on getting that but cant find one cheep enough. LOL I know its worth it but 500 is out of my price range right now........ so then I shouldn't need to tune it then right?
Never mind I seen u already told me thanks
I didnt see a ecu in that list. If your putting a 4g63t motor in there you will need the ecu from a 4g63t car. Or a tune.
No problem, I would put that on the top of your list. :thumb: (besides the regular stuff.)
Yea that will be on the top of my list trust me
Oh LOL ok. Didnt see that. Ya then if you stick to stock mostly you should be fine
Yea thats what I was trying to figure out had this car 4 days and blew it up cause the guy I got it from just slapped a turbo in without a tune
Weaker bearings??? The entire trans is different. Yes it bolts up but it is a different unit entirely. No not all 1g trans are the same. Nt is model f5m22. Turbo is f5m33...in fwd. A few internal pieces might be the same but for sure bell housing, gears and in 93 up axles and front diff are different.
Yup. The 1G fwd turbo trans uses tapered roller bearings on all shafts and diff. The trans for the 1G fwd non turbo 4G63 uses regular ball bearings. Not a big deal at stock turbo power levels but it makes a difference as the power goes up.
I guess I should've asked first,
Which trans are you using?
