DIY urethane motor mounts
cantgo2fast
188
Jul 2, 2009
Fort Collins, Colorado
I wasnt sure where to put this because its not a true write up but i figured I would share my little project.
I didnt want to pay 100+ dollars for motor mounts or go through the hassle of burning/pressing the stock ones. My driver side motor mount was completely torn in on spot so I decided to fill it using forsch liquid urethane. You can buy it multiple durometers. I went with 60A because I read on a nissan forum that that was a big upgrade but the 80A was pretty solid. Duct tape (becasue its waterproof) the back side VERY heavily then mix the urethane and pour! :) heres the result.
Looks good I've tried window weld which worked great for a few years but it separates. I finally went with poly mounts which if you have access to a press are easy to pit in I'd say it took me less time pressing them out and in then the cure time plus my kit with all 4 was about 60$.
each one of these kits runs $33 from mcmaster and you could do all 4 with two kits if you dont mess up LOL. so about the same price. I will say that adding the hardening agent is very important so you need a small accurate scale. you can Source one from your local drug dealer...
I have found that the windoweld seperates too. What I do is cut a couple blocks of hard plastic to take up some of the space, and glue them in the spaces with window weld. I then fill the spaces in between with window weld. After that, I cut two pieces of 16ga steel to cover both sides. They have a hole cut in them about 1.125" so that there is clearance for the motor mount bolt tube. I also drill a 1/4" hole on each side and a couple 1/8" ones too. I then fill it up with window weld thru the 1/4" until it comes out the 1/8" holes. This allows them to be stiffer, but with some give, and no chance of seperating out. This also fixes the drivers side one when they are shot too.
YA at school we used the window weld on our race car s a dampener for the driveshaft but it didnt hold up to the torque and took forever to cure. This stuff is good to go in about 2 days and stood up better in the driveshaft. I was just putting this out there as another option.
