Poly Urethane mounts
If its a full insert, I would say yes, press or cut out. Are the sizes the same, full insert to your mount? If so, that should answer your question.
It's the exact same as the rear insert. I was just wondering as any info I have found on the 1G kit is all with the 2 halves that you insert into the stock mount. Seeing if anyone had the 'newer' kit and how they did it.
