420A Dayco Harmonic Balancer problem
Th3DooM
301
3
Jan 5, 2011
Dresden, Europe
Hey guys.
I have a big problem with a brand new dayco harmonic balancer. The old one was never replaced so I wanted to use a new one when doing the timing belt job. When opening the box it looked different to the oem balancer. After asking around that wasn't a problem for other 420A users... besides that, measurements were "exactly" the same.
Unfortunately the dayco harmonic balancer now won't fit on my crankshaft. At first we tried to sand down a bit on the inside and with the help of a hammer and an airgun it slipped maybe half the way over the shaft. We didn't notice that it wasn't on all the way when tightening the bolt with the airgun.
Now we have the problem that the balancer wont go further on the crankshaft or even come lose again without destroying the part. The airgun isnt helpful in any way and there's no way a puller can pull the pulley back.
Did anyone else ever experienced such a thing involving a premium manufacturer? Does anybody has an advice for me?
I contacted rockauto who sold me the part but I am in trouble at the moment because I live in Germany and there is no way to get the part from another source than that over here. Not even Chrysler or Mitsu distributes it anymore. Or is there any other parts number besides 04667772 ?
While I have never dealt with this manufacturer, I have had balancers stuck on, so I'll try and help with that. The bad new is that you run the risk of ruining the part removing it the way I'm going to suggest. An air hammer is the way to go, with as much force as you can get on the puller, rattle it with an air hammer on the face. Add some heat if you have to. At the min. I would have the part checked to be true before reusing it, if you heat it. Anti seize is your friend in the future. Alternately, spray it with lots of lube, leave the puller on it with tension overnight, spray more, add tension, repeat. Good luck.
Also these are an interference fit on the 420a. Next time you go to do this get a bag of ice and put it on the crankshaft. Let it get nice and cold.
Heat up the pulley with a torch get it nice and hot but not cherry red! Then throw it on and bolt it down. This will make it the install easier.
