General Custom EPROM question?
slwDSMnel88
Jun 29, 2016
Joshua, Texas
Recently purchased a 1g talon and the ecu has this on it, not very familiar with this so I wanted to see if anyone could help me out with what the numbers mean??
That is a burned chip for 550cc injectors, 11:1 AFR's and max timing of 19*. Timing seems high for gasoline and a tad high for E85. You can keep it, put a stock chip in or replace it with an ECMLink chip and have total control of the parameters yourself, if you have the need to do so.
Also has a 7800RPM rev limit and a 6000 RPM launch limit.
I wouldn't run it unless your setup is identical to the previous guys setup that used that chip. Good news is the ECU is already socketed so just buy yourself an ECMLink V3 package WITHOUT the ECU, and plug it in and go.
