1G Coolant Temp Gauge Doesn't Work
wangboy925
160
Oct 5, 2006
Melbourne, Florida
Recently my stock coolant temp. gauge on my dash has died (needle is pegged to the far left). The only thing I did under the hood was mess around with my intercooler piping. I noticed the temp. sensor connector inside the thermostat seemed loose and old so I replaced it and now looks like this:
http://i31.photobucket.com/albums/c387/wangbojy925/sensorpics001.jpg
Still no fix. I'm thinking it could the bad sensor that goes into the bottom side for the radiator. Plus the cooling fans come on just fine and there's no hard start-ups in the mornings. I don't think its the actual gauge itself that's inside the dash.
Nah..your far away from where the issue actually is:
Look underneath the area of the rad.cap and you'll see a small sensor to the right with a wire attached. That is the temp gauge sending unit. Either that wire connector has come off that sending unit, is loose, or the tang on the sending unit is also loose (which mine was and resoldered it back on for my gauge to work..) and needs either to be resoldered back on, or replace the sending unit.
The sending unit at the bottom of the radiator is what makes the fan run when coolant gets too hot.
-DSM
That isn't your coolant temperature switch, its the A/C thermoswitch. Its only purpose is to shut off your A/C if the engine starts to over heat. Check out this picture for what is what on a 1g tb. Hope you find this helpful!
The one that controls the factory gauge is the one on the bottom right that has a single wire going to it.
If you are referring to number 6 (your link didn't work for me), then it won't matter if you no longer have A/C.
Sorry for reviving an old thread, but I am a little confused about my coolant gauge. It seems to only have two settings, medium-ish temps or off. when the car is off the gauge is all the way down, the second I start the car it goes to the medium-ish location and stays there no matter how hard I run the car. It doesn't slowly creep up as the car warms up either it just jumps straight to the location about halfway up on the gauge.
Referring to post #6 (which by the way is an awesome piece of information), I believe that I need a new water temperature gauge unit (4) but I wanted to get a second opinion before I make the purchase. My car is a 2G GST, I know the thread is for a 1G but I do not believe that matters but the info is there if it makes a difference.
Thanks in advance.
Logic would suggest that is the culprit, yes. But you may check the wiring running to the sensor as it may have become brittle over the years. In any case, it's a $15 sensor; it won't break the bank replacing it.
Also, for a 2G turbo car:
You can test the wiring and the sensor by simply grounding the wire that goes to the temp gauge sensor to a spot on the engine.
If the wiring and the temp gauge themselves are both in good working order, the gauge should read full hot. At that point, you can clean the temp sensor connection and try it again. If that doesn't solve the issue, replace the sensor as it is bad.
