Compression
ThompsonRacing17
46
Nov 16, 2012
millersburg, Ohio
hi i have a 1g eclipse with the 4g63 2.0 n/t ... i bought this car for a dirt track car and its race ready... it sounds really mean and we did a compression test and the compression is 250 psi... i was wondering if that is really good? or what should it be to be considered as "high compression" pistons say "63dM". any help would be greatly appreciated... note... in my division your suppoed to be stock... i know 250 psi cannot be stock...
On the top of my pistons it say 63dM... are these stock or?? Its a 4g63 n/t
Milled head, decked block, bigger cams, tighter centerline of the cams (less over lap) A smaller CC cylinder head, flat top or dome pistons. Stroker crank.
Just to name a few.
If you are supposed to be stock, pull the VC, and check the cams, there should be a large letter on the cam just behind the #1 cam journal.
Also check the back of the head and see if there is a casting number.
Have you seen this compression on a gauge for yourself or is this someone's word? Don't believe it until you see it.
If you didn't witness the compression test or didn't do it yourself. Than do one yourself or ask the mechanic to perform one infront of you and show you the numbers on the guage.
This is your 3rd thread on the same topic, the 2nd with an improper title.
I have responded in the other thread you started a couple days ago.
What the hell? What kind of pistons do you have? Didnt know they made that high a CR. You must have 11:1s or something really high.
Mine is at 180, stock CR 2g mahles
No LOL its not its a dirt track car and most the fast cars got about 165 horsepower. I'm hoping to beat that. And I doubt just shaving the head would give me that much compression. And I don't think whoever did the work would put the motor in jepordy by shaving it that much seeing how its raced every Saturday
What kind of fuel is this thing running? Diesel?
Literally laughed when I read this. I'm wondering now if that would actually kinda work. Run the car on gas for a while, heat it up. Drain the tank, diesel it up, disable ignition and go. ROFL.
One of the many things I've wanted to do to a car.
I have been in Pcola since 1986.
I do machine work for those along the Gulf Coast.
If you will go look, and maybe get a few pics of what I have asked you in the posts above, I may be able to help you figure why you have compression in the 250psi range
Lmao he could put a hx40 on it and call it a 4g6what cummins? ROFL
In all seriousness though, i doubt that would work on a stock 63 rotating assembly. They already fail miserably when knock occurs. A diesel engine is knock city
You know more than I do when it comes to that aspect. I'm just now learning gas, don't know more than the basics about diesel LOL. I'd have to tear down a volkswagen TDi to see what the differences really are. I really am interested in how his compression is that high. Its kind of impressive.
Yea im just wondering what its running on. Would have to be straight meth. As for a diesel, to do the conversion would involve machining a cast head for a set of diesel injectors where the plugs normally go, setting up an injector pump, locating the glow plugs in the head. Diesels inject the fuel after the intake valve is closed, when the piston is already coming back up on the compression stroke so that it takes in as much air as possible on the intake stroke
Basically A LOT of work. I did some reading up on diesel engines a while back, just out of curiosity on how they can run 60psi without exploding.
What would be ample pressure for gas to detonate at full operating temperature?
Too many x factors i would think. But that would definitely be worthy of a write up for the tech articles if someone could come up with an equation. Say (x)Crx(y)xIATx(z)fuel amountx(a)mass air
