Spoolin98
- 1,646
- 23
- Feb 1, 2004
Easton,
Pennsylvania
I have a done a ton of reading about Disengagement problems and Im confused as what to do...
Heres the deal, its going to be long but please read if your serious about helping me figure this out.
I had a stage 1 shep trans with no LSD, ACT 2100 pp with a street disk and a ACT streetlite flywheel. I had not problems shifting.
I upgraded to a stage 2 shep trans with quaife LSD, a southbend pp and southbend kevlar clutch. AFTER installing everything I am now finding posts that the kevlar clutch may be too thick creating Disengagement problems...
Once installed I could not get the car into gear at all. I loosened the bracket holding the shifter cables to the trans and shifted the bracket as far forward (towards the bumper) as possible. I adjusted the pedal stopper out (but still engaging the cruise switch). Then I adjusted the master rod clockwise (looking at the firewall) until it blocked the bleeder valve inside the master. I backed it off a 1/2 turn at a time till it no longer blocked the valve and I could push the slave rod in by hand. I followed the jacks transmission video.
Im still confused as to whether I did this correct or not?
First question, can you over adjust the main rod while not blocking the internal valve? Could this be my problem?
After doing these things I could now get it into gear, but it was still fighting me. Something wasnt right. So I bled the clutch line and it got a little better.
I could now drive the car but it would not let me into 1st gear unless I was rolling to a stop or at a stop I had to shift into 2nd gear first, then into first gear.
Something is still wrong. I talked to Trevor at Sheptrans and he suggested putting an extended slave rod in and adjust the main rod again. I spoke with Tim Zimmerman, TMZ performance, he suggested I drive the car easily and break the clutch in. Then readjust the main rod and I will be good to go.
My problem is that everywhere I read it states DO NOT use an extended slave rod and DO NOT drive the car with a dragging clutch. Yet both vendors are telling me to do things that are highly suggested not to do.
Some side notes:
The transmission is new so the synchros are good.
The flywheel is new, the step height was verified correct by my machinist.
The master and slave have no leaks and are fairly new, they worked before this install.
The TOB fork is a little to the right of the center of the rubber boot, closer to the slave rod.
My pivot ball is NOT shimmed because it didnt need it.
I bled the clutch by having my friend pump the pedal and hold it to the floor, then I cracked the slave valve and let fluid come out. Then I closed the valve and he would let the pedal come up and pump it again and hold it to the floor. We did this a few times. I didnt put a vacumm line into a half filled bottle like some say to do, I just put a vacumm line on and let it squirt into a bucket. I dont see the line not being bled correctly as the problem because it worked fine before.
2nd question, should I put an extended slave rod in and break in the clutch and then remove it? Maybe the break in will thin the clutch enough for proper Disengagement?
I would rather not pull the transmission to try a different clutch. Especially when TMZ is telling me im over thinking this and to just drive the car and I will be fine.
Any suggestions on what I should do next?
I just found this...
http://www.dsmtuners.com/forums/art...how-properly-bleed-your-hydraulic-clutch.html
Is this how everyone bleeds their clutch lines?
I never heard of bleeding any line without pumping the pedal.
I also never heard of bleeding the slave cylinder by removing the bleeder valve.
If this is how I should be doing it, maybe this is my problem?
I also found this one.
How to Bleed a Hydraulic Clutch - Team Rip Engineering
Which is slightly different.
Either way, I never bled my system like these tell you to.
I had my friend pump my clutch and then hold to the floor, and I never "purged" the slave cylinder.
Well I guess this is number one priority, keeping my fingers crossed!
My friend has a vacumm bleeder, If I use this to bleed the clutch line do I still have to bleed the slave cylinder seperately or will the vacumm bleeder pull all the air out of the whole system?
Some side notes:
In fact, I think their instructions showed it clearly with that spacer installed. And the pictures I took show the clip off of the TOB near the top. Now this thread's got me all kinds of worried.
