change a 14b for a ct26
Not to preach, but if I were you I would take the 14B to its full potential BEFORE trying to get another turbo...
I mean, from looking at your profile it looks like you have a long way that you can take that little guy.
Don't give up on the 14B till it gives up on you!!
good luck!:dsm:
I'm confused, are you talking about a new car, or just a new turbo.
Celica all-tracks are awesome cars, I would trade my dsm for one any day. But if you are just talking about turbos, a ct26 can make 350whp, but it's not worth the hassle in order to make it bolt up. Just go with a 16g.
all-tracks are one heavy bi***, thats the one factor that would keep me from ever getting one
Yeah supporting mods first. people have ran high 12's and beyond with 14b's
I dont know how accurate your profile is but id look into getting some sort of fuel management instead of a turbo. Back when i was running a 2gmas with an safc, I could easily max out the rc 550 injectors I had as most people can.
For not that much money you could get into a afc/logger setup and 550s or even 650s if you look around.
+1 :thumb:
Im running the 2gmas, 550's and an afc and it brings out good stuff with the 14b.
The ct26 will only flow 15~ to about 5500 rpm at that point the restrictive exhaust housing chokes it out.
I run a 50 trim ct26 on my MR2 and it holds 18~ till 7200.
The 16g way out flows the ct26 in stock trim. Plus you dont need a custom manifold or adapter with the 16g.
