Ludachris
Founder & Zookeeper
- 8,937
- 4,919
- Nov 12, 2001
Newcastle,
California
After reading a number of threads that talk about the appearance of the coatings, I'd like to have a discussion about its functionality in relation to road racing and open tracking. I've used the Jet Hot 2000 coating in the past and was happy with it but never did any temp testing. I'm considering getting my FP manifold re-coated this winter and was going to go with Jet Hot, but I know some of our supporting vendors do ceramic coatings and figured it might be worth looking into.
From what I've read, it seems the Jet Hot 2000 option will hold up to the highest temps (around 2400 degrees) where the ceramic coatings are said to hold up to around 2000 degrees. However, I haven't been able to find much info comparing the two coatings in terms of how effective each coating is for reducing underhood temps. Jet Hot mentions that their 2000 degree coating isn't as effective an insulator as their Sterling/Extreme Sterling coating (1300 degree coating), even though it can withstand higher overall temps. So does that mean ceramic coatings would be more effective below 2000 degrees as well? Anyone find any good data on this?
I'd like to keep this discussion specific to these two coating options, without bringing up thermal wrapping. Please chime in if you have any data.
