Please Support Kiggly Racing
aaronmatusz's Talon TSi AWD
Eagle Talon TSi AWD
Build Type
  1. Autocross
EVO III 16G turbo,
FP exhaust manifold,
190 lph pump,
PCV catch can,
K&N air filter,
Custom hard pipes,
550cc injectors,
3in turbo back,
fluidyne radiator,
Krazy custom FMIC,
DSMotorsport Oil cooler kit,
Mods-Engine
2.3L stroker: eagle rods and 8.5:1 forged pistons, 3G lifters, balance shaft eliminator kit
2G head heavily upgraded: +1mm valves, bee hive springs, bronze guides, port matched 2G intake manifold, BC stage II cams (like 272), adjustable cam wheels, ARP head studs
Mods-EMS & Logging
E- boost 2,
Greddy ETG,
DSMlink V3,
Defi oil temp and water temp,
AEM wideband
Mods-Drivetrain
Fidanza aluminum flywheel,
CFDF clutch,
Quaife LSD up front
Koni yellows
Ground Control coilovers,
ST rear sway bar,
front strut tower bar,
Stainless braided brake lines,
TCE big brakes,
17x8 Enkie wheels, Team Dynamics 17x9 on NT-01 tires
rear trailing arms with active toe welded out,
RRE camber/caster plates,
All the poly bushings I could get my paws on,
Custom rear subframe bushings,
Custom roll center correction
Parts Wishlist
Somebody please help me with ducting and aero!
sport seats, harnesses
1/8 Mile E/T
8.489
1/8 Mile MPH
80.170
279.0 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
Beyond Redline, WI
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : FP HTA68
Boost : 19
  • Like
Reactions: 3kidslater
aaronmatusz
More in 1G DSM
Share this Vehicle
