- Thread starter
- #101
Ceddy
- 847
- 42
- May 10, 2006
Reading,
Pennsylvania
You don't hear many people complaining about their turbo spooling too fast.
BigMaps helps by giving you more resolution, the stock map has differences up to 8* between cells. You want smooth transitions, with small of change as possible between cells. Also with the stock map you will have the same timing anywhere above 180 Load, you have different needs at 180 and 300 Load.
So, BigMaps probably won't help you. Maybe a dual stage boost controller run on low when cruising could help.
My car is really hard to drive without spooling and pulling with the setup I have.
(3" no cat and fully ported FP E3B16G ported EvoIII 02, Large FMIC and EBC)
I can get 20-22psi @ 2800rpms. At 1/4 throttle I still start making 15psi @ 3000 and it just keeps trying to spool me up. Is it settings on the Profec? I have changed it to slow spool up down. If feels same on quicker and slower settings.
Like I have to shift it I can't just climb in RPM's (unless really slow and lightly).
I feel like I wish I had a regular car sometimes cause it gets annoying when I just wanna cruise but will the big maps help smooth that out?
I had a safc-II before and I don't know how the difference between AFC tune and a ECU tune will be for driveability can someone enlighten me? Or what I might want to do when I get to tuning the ECU w/ECUflash.
I know when I get my next turbo I won't be complaining bout quick spool up when I got a 60trim or more.
