BLACK'98DSM
Moderator
- 5,473
- 2,974
- Feb 9, 2019
Alabama
I can't fill the tank up with gas! It goes for about a second and then cuts off. I think there is too much pressure building up. This didn't happen before I did the evap delete. So obviously I cut or capped something I wasn't supposed to.
I pulled everything except the 2 hoses for fuel pump, the 1 large hose for filler neck, and the 1 tiny hose that connects to the tank above the larger one. I'm thinking that I should have left THIS on:
Am I correct?
Am I correct?
. I have a hole in my filler hose somewhere so I can pump it normal either ha ha
