Resolved 2gNT What is this thing
2gDSM420a
Aug 30, 2008
Narvon, Pennsylvania
OK considering i don't know what this is (see pic), other then semi-circular seal according to Haynes, but when i ask for that at a auto parts store they have no clue what i mean, maybe you guys would.
This is a 420a motor from a 97 DSM, its on the driver side at the intake cam. i can find them for the 4g63 motor on rock auto but not the 420a, are they interchangeable?
It seams like mine is leaking, do i need to replace it or can i just pop it out ATV it and put it back?
If i need to replace it anyone know of a spot i could pick one up?
I did notice the ones for the 4g63 are rubber but mine is metal.
Thank you
^^^^^^ I agree
It looks like the half moon plug that you get with a valve cover gasket set. Usually you get the half-moon, 4 spark plug well gaskets, and 1 valve cover gasket in a full set. I'm not familiar with the 420a engine but I do know that on the 4G63, as long as it's still plyable with no cracks, you can reuse it with some rtv sealant. Use a very thin bead and you should be good.
d
Bane, on the 420a, the half moon is aluminum. ;)
As mentioned, though, if it isn't damaged, pull it out, clean, and reinstall with some silicone.
