88BB8B
- 179
- 19
- Oct 14, 2016
Coldstream,
BC, Canada
Total noob question, but I can't seem to find a straight answer. Can I use stroker pistons with a standard stroke crankshaft? I have found a really good deal on some JE pistons in my bore, but they say they are for the a 7 bolt 4g63 with 100mm stroke crank. I have the standard 88mm crank, and unfortunately 150mm eagles. Can I use these pistons with the 88mm crank and 156mm long rods? Or the 100mm crank and 150mm std rods? Or are there different pistons specifically for long rods? Also, these pistons are for the EVO 4-9. I plan on running a stock cam for a more useable powerband, you think my valves will clear? I'd like to take advantage of pin the offset if possible.
On another note, this might be a good opportunity to make this car a stroker. Assuming all I would need at this point would be the 4g64 crank, does anybody have a 7 bolt 4g64 crank they'd wanna trade for one of my 7 bolt 4g63 cranks? (preferably cut 0.25mm to match my bearings.)
OR
Does anybody have any eagle or similar 7 bolt H-beam long rods they would want to trade for my eagle H beam std length rods? mine are opened but never installed.
OR
