Can you define my transmission code?
sakroda
247
39
May 3, 2016
İstanbul, Europe
Hello
I have 1990 AWD talon can you define tranny code? is that from 1990 or else?
it looks NPGH when i check it s evo rs tranny please can you advice which clutch set matches with my tranny?
thanks
22 or 23 spline makes difference? i think I have 22 spline transmission maybe i am confusing:( please give me specific part number valeo or exedy maybe i can find here thanks a lot
You are talking about output shaft (22 or 23 spline). If your transmission is really Evo's transmission then actually you are supposed to have a 23 spline output shaft unless you have swapped it with 22 spline. (90 is 22 spline, 91~ is 23 spline).
As for the clutch disc, it goes to the input shaft. So just look for a clutch kit for 90 gsx.
thanks for reply i took a picture from tranny i don t think can t see 22 or 23 spline from images when i check from net it looks evo rs
So what you want to know is a part number for a clutch kit. Does not matter if your transmission is dsm or evo. But it MATTERS if AWD or FWD (flywheel is different) or Turbo or Non turbo (Pressure plate is different) . If you are looking for just a disc and a pressure plate, then does not matter what year your car is or AWD or FWD. Just it matters Turbo or Non turbo. All the same 90-99 Turbo AWD / FWD, so just choose one for TURBO model.
If you also want a flywheel then you have to choose one for AWD 6 bolt or 7 bolt, will be depending on what engine you have. (If your engine is originally from a 90 talon then you need a 6 bolt flywheel)
thank you for all messages We found valeo model.. We couldn t find an Exedy model:( I hope it works very well..
