Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
Replacing those shit cams is on my list
I guess the bc272s like my setup.Post #78I would have posted these sooner but I just got them in a email from the dyno lab. His network was down and could not send themredlines hks 264s blue line Bc 272s
Here is the 31psi run
I'll be testing out the new bc 276/276 stage 3 in a few weeks
Op, did you find the kelford 272s to be the best? As in no sacrifice in lower end with the biggest top end gains? A dyno plot on evo forums indicated the kelfords were best, then came gsc s2 then hks.
Then again i guess your working with re grinds... Which isnt really the same as authentic kelfords.
Read my posts in this thread. Finding a cam to be the best doesn't mean the most hp. the k272 are massive and made more hp than the bc272 but for a daily driver which is how my car is set up they are not the cam of choice. Best to me means over all performance not just power.
Drivability and the whole nine yards if you catch my drift. The subtle thing about my setup is my car is it sounds, idle and drive like a stock car, no loppie idle, no gas smell and excellent gas mileage just a nice smooth mild innocent running engine.
This is what confuses people locally that's able to actually hear, see and ride in the car, they just don't understand how does this car make so much power and don't sound like a race car. Its the balance in set up. the bc272s (set up with 20hg of vacuum at idle) , cyclone manifold, quick spooling 6266 is one of the best combination I have put together in all the years working with these cars and the best part my wife will ride in it now because it doesn't smell like gas at stop signs from some over size set of cams
I have bc 272's in my car also i know how they are. I was referring to the kelfords being best for drag
Kel what do you suggest for around 450 hp for cams, that's my next goal.
How do Crower 272s stack up? I have heard they are "better" than bc 272s and more along the lines of an hks 272.
BTW, i just got off the phone a few hours ago with delta. They will indeed make me a kelford 272 regrind. They are not listed and you have to ask for them. I would need to send in my crower 272s, NOT stock cams for this to be done. Total cost for both cams: 140. He said the crower would make a good core to do the k272 grind on. I know very little about cams and degreeing them in but its in the works.
In fact, im thinking the crower 272s i have now might be worth keeping. Coupled with some supertech dual valve springs, head porting and a 3786FP i think i can hit 600whp. But the top end of the K272 is very tempting.
Any thoughts on my cams? Keep em or go K272 for $140?
If you look at my setup you can tell I am not a fan of a lot of rmp, just too harsh on the engine in my book. That is why I built my car to get it down low and let me tell you I love it this way and so does my oil pump and the rest of my engine is happy as well
Wow I bet its a surprise to some folks that they could make 600+ on a 264 264 setup with the right balance of parts.
Finally done reading all this. Only took me...um, however many hours. Lol.
Awesome thread. Just wish that 1.) You could've tested the GSC cams, and 2.) Wish these cams could've been tested on different displacement motors. I'm sure the "streetablility" of bigger cams on a stroker would be much different than on a 2.0 motor. Or so I'd assume anyway.
And sorry to hear about all the bad luck you were having.
