2G Cam angle sensor
Eclispe Rs
Sep 15, 2024
San jose, California
I keep ordering the wrong parts any one selling this I guess they did a 97-99 cas swap mines a 2g eclipse 95 gsx or a link to a website where I can find the part I need
You have a 2gb cam sensor on the motor, in the package you have a used 2ga cam sensor, what you need is just a 2gb plug to go on the 2ga wires in your harness, you might need to extend those wires slightly to reach.
Looks like pin is bent but that can be bent back. Maybe that is why he is asking for a new sensor. Long as the sensor is good and the plug and pin's good then yes just needs need's to adapt it. We have done this on 95-96 cars before before. Memory say's also it needs the signal to be inverted too.
Thank you I appreciate it a lot ima order this one and it just needs to be wired into main harness and what wires just match the colors?
It’s been a pain for this project and it stops at 4k rpm and I think that’s why
On the website, it gives me two options the pigtail or the terminals connectors, et cetera? Do I pick both of them or do I just pick the pigtail?
Assuming your harness is still original (verify for us?) and that you are wanting to use the 2Gb cam sensor you show currently installed on your motor, what you need is the cam sensor adapter shown in the last picture of your original post.
Yes. 2g dsm with both crank and cam sensor if the cam sensor is not reading or even 180 deg off the car will not run from my experience.
Ok makes sense so I found out why it was like that and it was because I blew a head gasket so I’m just going to fully build the head at this point
