Broken Clutch Safety Swith
nsrmotorsports
45
Oct 8, 2008
Spring, Texas
I was out cruising last night on Fry Rd and was just about to get into 2nd to get moving again and i heard a loud pop:cry:. luckily i was still in neutral and just coasted into the O'Reiley's. I found part of the safety switch on the floor. Can i just find that piece in a junkyard or do i have to replace the entire clutch master cylinder
your question makes no sense. the clutch safety switch is simply a button on the clutch pedal assembly that, when depressed, doesn't allow you to turn on the motor. if you can't get your car to start because you broke the clutch safety switch then disconnect the wire going to the back of it and problem solved... the master cylinder has nothing to do with the safety switch thats why your question makes no sense.
http://www.dsmtuners.com/forums/drivetrain-tech/13894-how-do-you-disable-clutch-starter-cutout-switch-thing-merged-10-6-a.html
:dsm:
And by the way come home to Htown-dsm.com. Mike at FIST is the Texas DSM God FIST-RACING.com
Safety switch? People actually use those? I really doubt that's what popped, or what you found on the floor. If it is, it's probably consequential from another problem, though I have no clue what that problem would be. Just disconnect the switch and go on without it, if you notice any other stupid behavior, you'll know something else is to blame.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
