1G 1g manual Need help with no start/clutch safety switch bypass
skunkprodigy
5+ Year Contributor
45
5
Nov 17, 2017
flint, Michigan
I've read through tons of stuff but need help or pics of what to unplug front or back switch on the clutch safety switch and if I bypass or not.
I'm having problems with car firing up . Has gas and did turn over but now it won't turn over just the starter engaging.
Thanks for any help, just had house broken into took my keys stole my van. Only vehicle I got is my 93 awd talon 5spd. I installed a different full column and keys. Now car won't start ..
Yesterday it turned over no problem wouldn't start . Now won't even turn over...it almost started but small backfire on 1 cylinder .....😔
The column change is fine. If the starter makes any noise at all, it is getting some kind of signal from it. If it won't "RUN" now, is a different deal. Make sure it has spark, fuel and compression.
Fuel yes compression yes, spark no. Which do i unplug for the clutch bypass? The front switch by the dash and relay panel or one by firewall/floor?
Check the PTU connection, the Coil connection and the Cam Angle Sensor connection.
If this is a 2g car check the Crank position sensor.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
