1G No start help 1G
90talontsi90
30
Feb 6, 2008
Pacific, Washington
Ok So I know this is a horrible newbie situation but oh well it happened now I have to fix it.
First thing- Car was running fine before all of this happens.
Go to start my car one cold morning and I hear some bad belt noise and then it stops and the battery light comes on I hope out and see that the alt belt snapped. I shut the car off and take the wifes car to work.
Since I live in an apartment and work during the daylight hours I have to wait untill the weekend to fix it. As the week goes on the temp drops down to the single digits. My antifreeze mix is closer to 75/25 then the 50/50 so I have some ice forming in the coolant lines and the thermostat housing. I take off the lower hose and loosen the other coolant lines so as it warms up any ice that had formed would melt out.
That weekend I put on a new alt belt and try to start the car and it cranks fine but I get no start, I check for spark and I get spark but no start. And it was cranking just fine.
Next weekend I go and try to start troubleshooting and then it wouldn't crank it just clicks.
So my thoughts are;
1. Dead coolant temp sensor, How do I test this?
2. MPI Relay?
3. Starter?
4. ECU
Now as I said the car was running fine right before this but last summer I was fighting a No start conditon that went away before I could solve the problem. So I'm not 100% sure that the partial freeze was at fault.
If its that cold and it been sitting it could be frozen fuel lines. Do you have any way of checking to see if you've got fuel pressure? After sitting for 2 weeks in the cold the battery probably died and that is why its just clicking now.
I can check for fuel by unhooking the line... little dangerous but it will tell me if there's fuel. And about the Battery I still have everything thing else working but I'll put my volt meter on it tomorrow and see what I get. Is there any way for me to test the MPI relay? Does the MPI relay even effect the starter?
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
