Nii
5+ Year Contributor
- 91
- 44
- Jun 22, 2021
Midwest City,
Oklahoma
I'm so stumped on why she wont start.
So my 1g is having and issue with the injector circuit to where the injectors wont pulse.
I have spark and fuel but the injectors won't fire. The car will run off starter fluid though. I put in brand new DW 1200cc Low Z injectors. The pigtails for the injectors are new. I've put the ECU in another 1g and it ran fine. The injector resistor pack has the correct ohms. The injectors are getting 12v to each injector.
I unplugged the TPS to see if that would solve the issue with no luck. I checked the CAS alignment by putting the engine at TDC and lining the dot on the CAS case with the divot in the CAS spade. I tried putting my black top CAS in and had no luck with that one too.
I'm stumped anyone have any ideas on what the issue could be?
